The WD Sentinel DS5100 includes WD Se 3.5-inch enterprise-class hard drives. Featuring a dedicated OS boot drive, dual/redundant Gigabit Ethernet ports, and dual/redundant external DC-in power adapter ports. This engineered redundancy, along with a bezel lock for physical security, adds to the reliability of this ultra-compact storage plus server that can be deployed virtually anywhere.
The WD Sentinel DS5100 is a complete, fully configured solution with automatic backup and restore software for up to 25 users and 50 computers, all at a very affordable price. By combining a single solution for both storage and server requirements, the WD Sentinel DS5100 is a great solution for any small business looking for their first server.
WD hardware engineering
The elegant design of the WD Sentinel DS5100 offers optimized serviceability, allowing you to replace data drives in seconds. With its specially-designed, mechanically-loadable and hot-swappable 3.5-inch hard drive design, there's no fumbling with trays and screws. -
Ultra-compact design
Using custom-built hardware and electronics, WD has incorporated an Intel Xeon class server into a quiet and cool compact chassis. The WD Sentinel DS5100 is able to fit on any shelf or desktop, or wherever space is at a premium. -
Enterprise redundancy
WD Sentinel DS5100 offers enterprise redundancy, with RAID or Windows storage spaces, for up to four 3.5-inch datacenter hard drives. It also offers dual Gigabit Ethernet ports, a second power supply and dual boot drives (in auto RAID 1). -
Drive/bezel lock for theft deterrence
The drive/bezel lock and security lock slot of the WD Sentinel DS5100 are included for theft interference and deterrence.
- WD Sentinel DS5100 WDBYVE0040KBK - tower - Xeon E3-1220LV2 2.3 GHz - 8 GB - HDD 2 x 2 TB, HDD
- Server - tower - lockable front door
- Localisation
- Region: EMEA
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1220LV2 / 2.3 GHz (, up to 3.5 GHz, (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 8 GB (installed) / 32 GB (max) - ECC
- Storage Controller
- RAID
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- 2 x HDD 2 TB (hot-swap)
- Hard Drive (2nd)
- HDD
- Optical Storage
- No optical drive
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- Microsoft Windows Server 2012 R2 Essentials
- Black
- 16 cm x 22.35 cm x 20.57 cm
- 5.35 kg
- Limited warranty - 2 years
- Server
- Recommended Use
- Small business
- Product Form Factor
- Tower
- Built-in Devices
- Status LCD
- 1-way
- Internal Bays Qty
- 2
- Hot-Swap Bays Qty
- 4
- Black
- Localisation
- Region: EMEA
Processor / Chipset
- CPU
- Intel Xeon E3-1220LV2
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- ECC
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 2 TB
Hard Drive (2nd)
- HDD
- Capacity
- 1
- Boot drive
Storage Controller
- RAID - integrated
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Gigabit Ethernet
- Remote Management Protocol
- HTTP, HTTPS
- Bays
- 2 (total) / 1 (free) x internal 2.5" , 4 (total) / 2 (free) x hot-swap 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x memory
- 2 x LAN (Gigabit Ethernet) - RJ-45 , 4 x USB 3.0 , 2 x USB 2.0 , 1 x management , 1 x VGA
- Included Accessories
- 2 x keys
- Cables Included
- Network cable
- Lockable front door
- RoHS, Directive 2002/95/EC
- Power adapter
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
Operating System / Software
- OS Provided
- 16 cm
- 22.35 cm
- 20.57 cm
- 5.35 kg
- 0 °C
- 35 °C
- 5 - 95%
