WD Purple NV 6TB Surveillance AV Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5"
Quicklinx: BQWPWS00 Mfr#: WD6NPURX
Designed specifically for NVR digital surveillance systems, the WD Purple NV hard drive adds support for systems with higher drive bay configurations and up to 64 HD cameras. The increased number of video streams and workload capability offered with the WD Purple NV hard drive allows scalability beyond the limitations of DVR systems where only the WD Purple drive is applicable.
  • NVR vs. DVR
    WD offers the Power of Choice when it comes to equipping a surveillance system for your home or business with the addition of WD Purple NV. Designed specifically for scalable network video recorder (NVR) surveillance systems, WD Purple NV adds support for systems with higher drive bay configurations and up to 64 high-definition cameras. The expanded workload capability of WD Purple NV hard drives enables the ability to handle increased video streams, allows scalability beyond the limitations of DVR systems where only WD Purple is applicable.
  • Increased capabilities
    Designed for higher temperatures and always-on surveillance environments, WD Purple NV hard drives expand support for higher hard drive bay configurations, systems utilizing up to 64 high-definition cameras, hardware vibration sensors and greater workloads per year when compared to WD Purple hard drives. Included with the increased support, WD Purple NV is also backwards compatible with DVR systems.
  • Optimized performance with AllFrame
    Inherited from WD Purple, WD's exclusive AllFrame technology boosts write performance for WD Purple NV hard drives by working with ATA streaming commands to reduce frame loss and improve streaming playback. AllFrame also reduces video interruptions that commonly occur when desktop hard drives are incorrectly used as storage in security systems, especially in higher video stream count environments where additional data is being captured at an exponential rate. WD Purple NV with AllFrame provides the confidence you should expect when it's time to play back and review critical surveillance footage in larger surveillance configurations.
  • Premium protection
    Designed with tarnish resistant components, WD Purple NV hard drives offer premium protection in harsh environments where surveillance systems are commonly installed including outdoor cabinets where moisture and other natural elements may be present. This increased protection adds reliability to the hard drive over time, especially compared to desktop drives.
  • Support for high camera count systems
    WD Purple NV hard drives are optimized to support systems utilizing high-definition surveillance cameras, giving you the flexibility to upgrade and expand your security system in the future. Higher storage capacities also allow you to store the surveillance footage for a longer period of time, especially in situations when every second counts. The specific number of cameras that can be supported will be dependent on a number of criteria including but not limited to; types and capability of cameras installed (resolution, frames per second, additional features) and the system's hardware and software capability.
  • Lower power consumption
    Low power consumption is crucial in high-temperature always-on surveillance environments. With exclusive IntelliSeek technology, WD Purple NV hard drives calculate the optimum seek speeds which lowers power consumption, noise and vibration that can damage and cause drives to wear out more quickly, increasing reliability.
WD Purple NV Surveillance Hard Drive WD6NPURX - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliSeek, IntelliPower, Advanced Format technology, AllFrame, surveillance system compatible, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
720 g
3-year warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
171 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
5.9 Watt (read) , 5.9 Watt (write) , 4.9 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
Apple MacOS, Microsoft Windows 7 / Windows 8
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 3 years
65 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
25 dBA
