WD Purple 1TB Surveillance AV Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5"
CLEARANCE!
Clearance
Limited Time Offer
Quicklinx: 99CHWS00 Mfr#: WD10PURX
WD Purple Surveillance Storage: 3.5-inch, SATA 6 Gb/s, IntelliPower - The evolution of surveillance.
WD Purple Surveillance Storage offers exclusive AllFrame technology to bring you premium reliability and peace-of-mind when installing your home or small to medium business security system. WD Purple's exclusive firmware upgrades work with ATA streaming to reduce error pixilation and video interruptions that occur when desktop hard drives are incorrectly used as storage in security systems. WD Purple Surveillance Storage is built for 24/7, always-on, high-definition surveillance security systems that use up to eight hard drives and up to 32 cameras.
Choose a drive that is designed and engineered for home and business surveillance systems and enjoy the peace-of-mind you can only get from a surveillance-class hard drive.
WD Purple Surveillance Hard Drive Features
Ideal For
  • Security systems that want 24/7 surveillance reliability Surveillance security systems using PVR, DVR, NVR recorders.
  • Security applications that require reduce error pixilation and video interruptions
  • Surveillance-class storage performance that use up to five hard drives and up to 32 cameras.
Compatibility
  • Specifically designed for Surveillance security systems using PVR, DVR, NVR recorders that use up to eight hard drives and up to 32 cameras.
Warranty
  • 3-year limited warranty
  • Surveillance you can trust
    With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust.
  • WD's exclusive AllFrame 4K technology
    All WD Purple drives are equipped with AllFrame 4K technology, which improves ATA streaming to help reduce frame loss, improve overall video playback, and increase the number of hard drive bays supported within a NVR. Futureproof your surveillance solution knowing that WD Purple is ready for ultra high definition cameras.
  • Enhanced workload rating
    With a high workload rating WD Purple is designed to handle the unique demands of modern video surveillance DVR and NVR systems.
  • Wide compatibility, seamless integration
    WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you.
  • Less power, more efficient
    With exclusive IntelliSeek technology, WD Purple drives are able to calculate optimum seek speeds. This keeps power consumption low so ambient noise and vibrations are at a minimum.
WD Purple WD10PURX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Time-Limited Error Recovery (TLER), IntelliSeek, IntelliPower, Advanced Format technology, AllFrame, surveillance system compatible, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
450 g
3-year warranty
My Cloud EX2; EX4
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
110 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
10 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
3.3 Watt (read) , 3.3 Watt (write) , 2.9 Watt (idle) , 0.7 Watt (standby) , 0.7 Watt (sleep)
Apple MacOS, Microsoft Windows 7 / Windows 8
ICES-003 Class B, RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Sound Emission
21 dBA
WD My Cloud EX2 , WD My Cloud EX4
Resources
The following resources are available for the WD Purple 1TB Surveillance AV Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5"
