Your basket is empty
WD Mybook Studio USB 3.0 6TB EMEA
Quicklinx: B62FWS00 Mfr#: WDBHML0060HAL-EESN
This drive is a high-performance answer to your Mac storage needs. Protect your digital life with visual backup software, drive encryption, and password protection. Use the innovative e-label to personalize your drive and easily archive media collections.
WD My Book Studio WDBHML0060HAL - hard drive - 6 TB - USB 3.0
Hard drive - external (desktop)
6 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, Apple Time Machine compatible, HFS+ formatted, aluminium enclosure
Power Source
Included AC adapter
48 mm x 135 mm x 165 mm
1.2 kg
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
6 TB
Hardware Encryption
USB 3.0
48 mm
135 mm
165 mm
1.2 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD Security, WD Drive Utilities
Apple MacOS X 10.6.5 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
5 °C
35 °C
