WD Mybook for Mac 4TB EMEA
Quicklinx: B62CWS00 Mfr#: WDBYCC0040HBK-EESN
The best-selling My Book external drive is an elegant, high-capacity storage solution for all the chapters of your digital life. My Book for Mac features visual, easy-to-use, automatic, continuous backup software and drive lock security protection. At last, beauty, brains, and simplicity together.
  • Massive capacity
    With a massive capacity so you can back up your photos library, download your music collection, and help protect every important file.
  • Universal connectivity
    Equipped with a USB port, the My Book for Mac drive delivers ultra-fast file transfers and greater bandwidth.
WD My Book for Mac WDBYCC0040HBK - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, Apple Time Machine compatible, HFS+ formatted
Power Source
Included AC adapter
Enclosure Colour
49 mm x 139.3 mm x 170.6 mm
1.03 kg
Middle East, Africa, Europe
3-year warranty
4 TB
Hardware Encryption
USB 3.0
49 mm
139.3 mm
170.6 mm
1.03 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD Security, WD Drive Utilities
Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
Package Type
Retail
Limited warranty - 3 years
5 °C
35 °C
