The best-selling My Book external drive is an elegant, high-capacity storage solution for all the chapters of your digital life. My Book for Mac features visual, easy-to-use, automatic, continuous backup software and drive lock security protection. At last, beauty, brains, and simplicity together.
Massive capacity
With a massive capacity so you can back up your photos library, download your music collection, and help protect every important file. -
Universal connectivity
Equipped with a USB port, the My Book for Mac drive delivers ultra-fast file transfers and greater bandwidth.
- WD My Book for Mac WDBYCC0040HBK - hard drive - 4 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 4 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Password authentication, hardware encryption, Apple Time Machine compatible, HFS+ formatted
- Power Source
- Included AC adapter
- Enclosure Colour
- Black
- 49 mm x 139.3 mm x 170.6 mm
- 1.03 kg
- Localisation
- Middle East, Africa, Europe
- 3-year warranty
- Capacity
- 4 TB
- Interface
- USB 3.0
- 49 mm
- 139.3 mm
- 170.6 mm
- 1.03 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Software Included
- WD Security, WD Drive Utilities
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable - external
- RoHS
- Enclosure Colour
- Black
- Localisation
- Package Type
- Retail
- Limited warranty - 3 years
- 5 °C
- 35 °C
