WD My Passport Ultra 2TB Gray Portable Hard Drive
Quicklinx: DL0LWS00 Mfr#: WDBTLG0020BGY-WESN
The My Passport Ultra drive is trusted, portable storage in a design that has a sophisticated style. With plenty of space to store all the content you love, it will help keep all your memories safe and secure. Easy to use, just plug it in to start saving and backing up.
  • Brilliant design
    The My Passport Ultra drive features a sophisticated style. This brilliant design fits comfortably in the palm of your hand, pocket or purse so you can easily carry the content you love anywhere you go.
  • Social media and cloud storage import
    Easily import your photos, videos and docs to the My Passport Ultra drive to help preserve your online life.
  • Back up automatically
    The My Passport Ultra drive helps make sure your photos, videos, music and docs don't get lost. Set it to your schedule. Pick the time and frequency to auto back up files from your system onto the drive.
WD My Passport Ultra WDBTLG0020BGY - hard drive - 2 TB - USB 3.0
Hard drive - external (portable) - password authentication, automatic backup, cloud backup
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, automatic backup, cloud backup
Power Source
USB bus
Enclosure Colour
Grey, black
81.5 mm x 110 mm x 13.5 mm
140 g
Worldwide (excluding China)
3-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.0
81.5 mm
110 mm
13.5 mm
140 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Microsoft Windows 7 / 8.1 / 10
1 x USB 3.0 cable - external
Directive 2002/95/EC
Enclosure Colour
Grey, black
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
20 - 80%
