WD My Passport 1TB for Mac Portable Hard Drive Black
Quicklinx: DL0JWS00 Mfr#: WDBFKF0010BBK-WESE
My Passport for Mac is the sleek, portable hard drive designed for photographers, graphics professionals and road-warriors who want to take their digital life with them. It's compatible with Apple Time Machine and is an ideal companion for your MacBook or MacBook Air. Password protection and hardware encryption let you secure your files from unauthorized access.
  • Sleek, compact design
    This compact enclosure offers plenty of storage making it the ideal companion for the graphic professional, student, or road warrior.
  • USB 2.0 interface
    Conveniently powered through the USB 2.0 interface, you can quickly connect to your MacBook or MacBook Air and access your files. There's no need to carry around a power adapter.
  • WD Security
    WD Security utility allows you to set password protection and hardware encryption for your drive to protect your files from unauthorized use or access.
  • WD Drive Utilities
    Register your drive, set drive timer, run diagnostics and more using the WD Drive Utilities.
  • Formatted for Mac
    HFS+ Journaled so it works right out of the box with your MacBook or MacBook Air. Can be reformatted for Windows.
  • Compatible with Apple Time Machine
    Back up your files with Apple Time Machine.
  • WD quality inside and out
    WD knows your data is important to you. So WD builds the drive inside to its demanding requirements for durability, shock tolerance, and long-term reliability. Then WD protects the drive with a durable enclosure designed for style and protection.
WD My Passport for Mac WDBFKF0010BBK - hard drive - 1 TB - USB 3.0
Hard drive - external (portable) - password authentication, Apple Time Machine compatible, HFS+ formatted, LED status indicator
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, Apple Time Machine compatible, HFS+ formatted, LED status indicator
Power Source
USB bus
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.0
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Discovery
1 x USB 3.0 cable - USB-C to micro-B - external , 1 x USB 3.0 cable - USB Type A to micro-B - external
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
