WD My Cloud Pro Series 4100 4bay Diskless Media Server NAS
Quicklinx: C5GCWS00 Mfr#: WDBNFA0000NBK-EESN
Capacity: 0GB
Interface: Gigabit Ethernet
  • Pentium
Hurry, only 1 left in stock!
£429.25 ex VAT
£515.10 inc VAT
The core of team collaboration
With space to keep virtually everything, the My Cloud Pro Series offers your creative team the network storage to edit, save and share production files from anywhere with an internet connection. Compatible with both Mac and PC, you're able to protect your content regardless of OS. And with all photos, videos and files organized in one place, your team has all it needs to streamline its creative workflow.
Storage to organize everything
With high capacity network storage, you get the space you need to keep all your shots organized in one spot. Combined with a quad core Intel Pentium N3710 processor and 4GB of RAM, you can seamlessly stream HD videos or share content with multiple users. Keep your production files, .RAW photos, or final mixes in a single place and ready for access with the My Cloud Pro Series.
Edit and save from anywhere
Keep your media collection in a single place and access, edit or save content from anywhere you have an internet connection. Share HD media with clients and customers, or improve your team's workflow with MyCloud.com and the My Cloud mobile app.
Backup for Mac and PC
Personalize how you want your digital collection protected with backup for every need. Save content from a PC automatically with WD SmartWare Pro, copy data to a separate My Cloud device, or easily back up a Mac through Apple Time Machine.
Stream anything
With built-in hardware transcoding and the downloadable Plex Media Server, your team can smoothly stream HD media wherever they have an internet connection. Hardware transcoding prepares media for streaming in the right format and quality, and with the Plex app installed on your NAS, you can beautifully stream to any device.
Data protection your way
Multiple RAID options help you protect your digital library however you need, while password protection and 256-bit AES volume encryption helps safeguard your files from prying eyes. Along with two power ports in case of a power supply failure, the My Cloud Pro Series helps keep your data safe.
Simple to setup, easy to use
The My Cloud Pro Series can be quickly found on your network and installed over the web, making the setup process simple and intuitive. And with tool-less, tray-less drive bays, you're able to easily add or replace hard drives in a matter of moments.
My Cloud OS
Get the tools and apps for complete control of all your media with WD's My Cloud OS. Create a media server with Plex. Synchronize content from all your computers with WD Sync. Or even back up your network storage to a supported cloud service like Dropbox, OneDrive or Google Drive.
Adobe Creative Cloud Connected
The Adobe Creative Cloud features tools to turn an idea into a masterpiece, and with the My Cloud mobile app, you can quickly get media from the My Cloud Pro Series and into the Creative Cloud to edit and save files from anywhere you have an internet connection.
WD My Cloud PR4100 WDBNFA0000NBK - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
32 TB
0 (installed) / 4 (max)
17 cm x 23.2 cm x 19.2 cm
3.46 kg
EMEA
1 x Intel Pentium N3710 1.6 GHz (Quad-Core)
Storage Controller
RAID RAID 0, 1, 5, 10, JBOD
GigE
RAM
4 GB
Power Redundancy
Optional
Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Microsoft Windows 7 / 8 / 10, Apple OS X 10.11 El Capitan
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
32 TB
17 cm
23.2 cm
19.2 cm
3.46 kg
Built-in Devices
Status LCD
EMEA
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.56 GHz
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
GigE
DLNA Media Server, Apple Time Machine compatible, built-in hardware transcoding
Encryption Algorithm
256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x internal
2 x Ethernet 1000Base-T , 3 x USB 3.0
1 x network cable
Directive 2002/95/EC
External power adapter
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Software Included
WD Sync, WD SmartWare Pro, WD Access
35 °C
C5GC C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
C5GC C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
C5GC C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.11
C5GC C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.19
C5GC C2G USB Superbooster Extender Kit In Stock £38.85
Capacity: 0GB
Brand: WD
Price Range Ex VAT: 300 - 500
