Built from the ground up with hardware, software and storage from WD, My Cloud Business Series DL2100 is a true all-in-one, high-performance NAS solution designed for small businesses. The fully integrated, easy to deploy system provides the reliability, security, and scalability needed to drive small business success.
Keep your business data in one safe, efficient place
Centralize and protect critical business data from all the PC and Mac computers in your workplace on one, easy to manage NAS solution. And with secure remote and mobile access, you can get to it anytime, from anywhere to share files with employees, partners and customers. -
Performance to boost your business
Powered by a high-performance processor, My Cloud DL2100 delivers optimal multi-user and multi-application performance your business needs to maximize productivity. Ultra-fast read and high write speeds give your business the power to transfer large amounts of files simultaneously, enhancing workplace efficiency. -
Built-in reliability your business demands
My Cloud Business Series pre-configured NAS come populated with WD NAS hard drives. Ultra-reliable and purposely built for NAS systems, WD drives improve performance and thrive in 24 x 7 environments. -
Robust data protection to safeguard critical business data
Lost data means lost business, so My Cloud DL2100 offers comprehensive data protection options to secure your files from unexpected loss. Protect all the PC and Mac computers in your workplace using local, remote or cloud backup. Multiple RAID configurations and volume encryption add even more protection and security for all your files. And with dual NICs and dual power ports, My Cloud DL2100 keeps you connected to your data in case of network connection or power supply failure. -
Capacity and performance you need today, scalable for the future
My Cloud Business Series devices are designed to keep up with your future storage and performance needs. Easily hot swap in larger drives without turning off the device, keeping your business up and running. The built-in memory expansion slot allows you to increase RAM for improved system performance. For even more storage and speed, My Cloud DL2100 is equipped with dual Gigabit Ethernet ports that allow you to daisy-chain to another NAS device for increased network storage capacity. -
Seamless business environment integration
Integrate My Cloud Business Series NAS into your existing Active Directory for streamlined file sharing, easy data management and increased business efficiency. -
Perfect fit for virtualization environments
With integrated iSCSI support, My Cloud Business Series NAS easily provide storage for virtual machines, applications and servers on your network, giving you fast access to your business data. -
Automatically copy your external USB with the touch of a button
With the built-in, one-touch copy button conveniently located on the front of the system, you can automatically copy all the files you have stored on an external USB to the My Cloud DL2100, keeping all your business files in one safe, central location.
- WD My Cloud DL2100 WDBBAZ0120JBK - NAS server - 12 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.86 cm x 21.61 cm x 14.78 cm
- 3.65 kg ()
- Localisation
- EMEA
- Processor
- Intel Atom C2350 1.7 GHz (Dual-Core)
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB SATA 6Gb/s - IntelliPower, NASware technology
- Networking
- 1GbE
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple OS X 10.8 Mountain Lion, Apple OS X 10.7.5 Lion, Windows 8.1, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 10.86 cm
- 21.61 cm
- 14.78 cm
- 3.65 kg ()
- Enclosure Colour
- Black
- Built-in Devices
- Led panel
- Localisation
- EMEA
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 1 GB (installed) / 5 GB (supported) - DDR3
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 2 x 6 TB
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Data Link Protocol
- 1GbE
- NTP, iSCSI, Bonjour, DDNS
- Remote Management Protocol
- SNMP 2, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Internet Storage Name Service (iSNS), Web-based Distributed Authoring and Versioning (WebDAV)
- VLAN support, IPv6 support, SSH support, iTunes server, Jumbo Frames support, FTP server, static IP mode, UPnP Media Server, IPv4 support, TwonkyMedia server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), DHCP client, e-mail notification, cloud backup
- Encryption Algorithm
- 256-bit AES
- IEEE 802.1Q, DLNA CERTIFIED, UPnP
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Ethernet 1000 - RJ-45 , 2 x USB 3.0
- Cables Included
- 1 x network cable
- Wake on LAN, UPS support, automatic fan speed control, firmware upgradable, scheduled power on/off, Full Volume Encryption, RAID Level Migration, Spin Down Idle Disk, tray-less design, one-touch copy button
- RoHS, Directive 2002/95/EC
- Power Device
- External power adapter
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- Software Included
- Photos, WD My Cloud, WD Quickview, WD SmartWare Pro (25-users licence)
- OS Required
- Limited warranty - 3 years
- 0 °C
- 35 °C
