Your basket is empty
WD Blue 750GB Mobile 9.5 MM Hard Disk Drive - 5400 RPM SATA 6 Gb/s 2.5 Inch - WD7500BPVX
Quicklinx: 8RH4WS00 Mfr#: WD7500BPVX
Form Factor: 2.5" x 1/8H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 750GB
Spin Speed (rpm): 5400rpm
£41.34 ex VAT
£49.60 inc VAT
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
WD Blue WD7500BPVX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock Guard, WhisperDrive, SecurePark, Advanced Format technology
69.85 mm x 100.2 mm x 9.5 mm
150 g
2 years warranty
750 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
9.5 mm
150 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
138 MBps
Track-to-Track Seek Time
2 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
RoHS
60 °C
8 - 95%
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Type: Hard drive
Capacity: 750GB
Brand: WD
Price Range Ex VAT: 0 - 50
