WD Blue 500GB Desktop Hard Disk Drive - 5400RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD5000AZRZ
Quicklinx: BKXTWS00 Mfr#: WD5000AZRZ
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 5400rpm
33 in stock
£34.82 ex VAT
£41.78 inc VAT
High Capacity, Proven Reliability.
WD Blue hard drives deliver solid performance and reliability for desktops PCs, external enclosures and for certain industrial applications.
  • High storage capacity
    Boost your PC storage with the hard drive, which delivers spectacular data storage capacity.
  • Improve PC performance
    Pair a larger capacity drive with an SSD to give your desktop a performance and storage boost. The SSD maximizes speed of data access, while this hard drive stores enormous amount of movies, games, files, applications and more.
  • Future-proof your storage
    With better technology comes bigger storage needs. Cameras that record ultra-high definition video at 4K resolution at 30 frames per second require a ton of storage. Handling all that media is a snap with this drive, capable of storing large amounts of data.
  • NoTouch ramp load technology
    This technology safely positions the recording head off the disk surface to protect your data.
  • IntelliSeek technology
    This technology calculates optimum seek speeds to lower power consumption, noise and vibration.
  • Data LifeGuard
    The technology which ensures the algorithms monitor your drive continuously so it stays in optimum health.
WD Blue - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal - Data Lifeguard, IntelliSeek, NoTouch ramp load technology, Advanced Format technology
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
101.6 mm x 147 mm x 26.1 mm
450 g
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
3.3 Watt (read) , 3.3 Watt (write) , 2.5 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
RoHS 2011/65/EU
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
350 g @ 2 ms
Sound Emission
21 dB
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: WD
Price Range Ex VAT: 0 - 50
