WD Blue 320GB 16MB 2.5" SATA 6Gb/SEC Internal Hard Drive
Quicklinx: CPQ6WS00 Mfr#: WD3200LPCX
Form Factor: 2.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 320GB
Spin Speed (rpm): 5400rpm
44 in stock
£33.16 ex VAT
£39.79 inc VAT
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
  • Low power consumption
    Amazing seeking algorithms and advanced power management features ensure low power consumption and long battery life.
  • Quiet
    In a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield one of the quietest 2.5-inch hard drives on the market.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
WD Blue WD3200LPCX - hard drive - 320 GB - SATA 6Gb/s
Hard drive - internal - NoTouch ramp load technology, Advanced Format technology
320 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
320 GB
2.5"
SATA 6Gb/s
Buffer Size
16 MB
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.4 Watt (read) , 1.4 Watt (write) , 0.55 Watt (idle) , 0.16 Watt (standby) , 0.16 Watt (sleep)
RoHS, NMB-3 Class B, CAN ICES-3 Class B
60 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 2 ms
Sound Emission
17 dBA
Form Factor: 2.5"
Type: Hard drive
Capacity: 320GB
Brand: WD
Price Range Ex VAT: 0 - 50
