WD Blue 2TB Desktop Hard Disk Drive - 5400RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EZRZ
CLEARANCE!
Clearance
Quicklinx: BKXQWS00 Mfr#: WD20EZRZ
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 5400rpm
Hurry, only 2 left in stock!
£43.57 ex VAT
£52.28 inc VAT
High Capacity, Proven Reliability.
WD Blue hard drives deliver solid performance and reliability for desktops PCs, external enclosures and for certain industrial applications.
WD Blue WD20EZRZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal - Data Lifeguard, IntelliSeek, NoTouch ramp load technology, Advanced Format technology
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
101.6 mm x 147 mm x 26.1 mm
600 g
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
600 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
4.1 Watt (read) , 4.1 Watt (write) , 3 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
RoHS 2011/65/EU
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
23 dB
Type: Hard drive
Capacity: 2TB
Brand: WD
Price Range Ex VAT: 0 - 50
