Product
WD Blue 1TB Desktop Hard Disk Drive - 7200RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
Quicklinx: 8757WS00 Mfr#: WD10EZEX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
Hurry, only 3 left in stock!
£34.07 ex VAT
£40.88 inc VAT
Express delivery Delivered on Tuesday
Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
  • A modern classic
    WD Blue storage is designed and manufactured with technology found in WD's original award-winning desktop and mobile hard drives. WD Blue sets the baseline for everyday storage by consistently delivering improved performance over previous generations while successfully maintaining WD's quality and reliability for over six generations. The difference is that colors never fade, generation after generation.
  • The WD advantage
    WD puts the products through extensive Functional Integrity Testing (F.I.T.) prior to any product launch. This testing ensures the products consistently meet the highest quality and reliability standards of the WD brand.
WD Blue WD10EZEX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
IntelliSeek, NoTouch ramp load technology
10.16 cm x 14.7 cm x 2.54 cm
440 g
2 years warranty
My Cloud EX2
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.16 cm
14.7 cm
2.54 cm
440 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
Sound Emission
29 dBA
WD My Cloud EX2
8757 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £32.89
8757 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
8757 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £64.25
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
