WD Black 500GB Performance Mobile Hard Drive - 7200RPM SATA 6Gb/s 32MB Cache 2.5"
Quicklinx: BCX4WS00 Mfr#: WD5000LPLX
Form Factor: 2.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£43.73 ex VAT
£52.47 inc VAT
WD Black drives deliver improved performance that heightens the experience of your PC playground. These performance drives offer enhanced features over the previous generation to maximize system performance, allowing you to have more fun creating while spending less time waiting.
  • Inspiring performance and capacity
    For the creators, the gamers and those that demand the best, WD delivered the next generation of hard drives to enlarge your PC playground. The latest WD Black desktop hard drives offer enhanced features that maximize system performance, allowing you to spend more time doing what you love most and less time waiting. WD Black is designed to intensify your PC experience with generous capacity and incredible performance, pushing the boundaries of personalization.
  • High resolution for a high definition world
    Underlying its athletic stance of performance and capacity, WD Black features a new High Resolution Controller (HRC) with an improved architectural design, resulting in increased data precision across the hard drive. This translates to superior responsiveness evolving your high definition world to the next level.
  • Smarter than the average drive
    Performance and workstation PCs equipped with high-end components often emit vibrations and acoustics that can reduce the precision and performance of your hard drive. Even the best chassis on the market cannot always compensate against this. The new generation of WD Black hard drives feature Vibration Control Technology (VCT) which allows the disks inside the drive to adapt to any mounting problems or vibration conditions that are inside your case, resulting in increased data accuracy, performance and reliability over time. Put simply, this means you can game harder, faster and longer.
  • Action meets stable traction
    In addition to Vibration Control Technology (VCT), WD Black is also equipped with StableTrac Technology, which secures the motor shaft inside the drive at both ends to help reduce additional system induced vibrations. StableTrac confidently stabilizes the platters inside, resulting in more accurate tracking in a particular sector during read and write operations and delivers increased performance.
  • Efficient dual processing
    When it comes to processing power, more is always better. WD Black features a dual core processor that offers twice the processing power to maximize drive performance. Adding additional value, WD's Dynamic Cache Technology increases performance by improving caching algorithms in real time and optimizing the cache allocation between reads and writes. This results in the drive automatically allocating more cache for read data, which reduces data congestion and increases overall performance.
WD Black Performance Hard Drive WD5000LPLX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal - dual processor, Advanced Format technology
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
Dual processor, Advanced Format technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
92 g
5-year warranty
500 GB
2.5"
SATA 6Gb/s
Buffer Size
32 MB
69.85 mm
100.2 mm
7 mm
92 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.3 Watt (read) , 2.3 Watt (write) , 1 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 2 ms
Sound Emission
23 dBA
Form Factor: 2.5"
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: WD
Price Range Ex VAT: 0 - 50
