WD Black 500GB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch
Quicklinx: 8921WS00 Mfr#: WD5003AZEX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 7200rpm
20 in stock
£54.70 ex VAT
£65.64 inc VAT
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
  • Maximum performance
  • No compromises
    High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive.
  • Dynamic cache
    WD's dynamic caching algorithm improves performance in real time by optimizing cache allocation between reads and writes.
  • Rock-solid mechanical architecture
    Enhanced reliability features help protect the drive and the data stored on it.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
WD Black Performance Hard Drive WD5003AZEX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal - dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor
101.6 cm x 14.7 cm x 2.54 cm
440 g
5-year warranty
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 cm
14.7 cm
2.54 cm
440 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.8 Watt (active) , 6.1 Watt (idle) , 0.8 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Sound Emission
30 dBA
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: WD
Price Range Ex VAT: 50 - 100
