WD Black 2TB Performance Desktop Hard Disk Drive 7200RPM SATA 6Gb/s 64MB Cache 3.5 Inch WD2003FZEX
Quicklinx: 90VNWS00 Mfr#: WD2003FZEX
Form Factor: 3.5 x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£107.18 ex VAT
£128.61 inc VAT
Express delivery Order within the next 21 hours for delivery on Thursday
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
  • Maximum performance
  • No compromises
WD Black Performance Hard Drive WD2003FZEX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, S.M.A.R.T.
101.6 mm x 147 mm x 25.4 mm
750 g
5-year warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
25.4 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
164 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
9.5 Watt (read) , 8.1 Watt (idle) , 1.3 Watt (standby) , 1.3 Watt (sleep)
RoHS, WEEE
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Sound Emission
29 dBA
Type: Hard drive
Capacity: 2TB
Brand: WD
Stock Status: While stocks last
Stock Status: Clearance
