WD Black 2TB Performance Desktop Hard Disk Drive 7200RPM SATA 6Gb/s 64MB Cache 3.5 Inch WD2003FZEX
Quicklinx: 90VNWS00 Mfr#: WD2003FZEX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
48 in stock
£94.13 ex VAT
£112.95 inc VAT
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
WD Black Performance Hard Drive WD2003FZEX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal - StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, S.M.A.R.T.
101.6 mm x 147 mm x 25.4 mm
750 g
5-year warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
25.4 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
164 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
9.5 Watt (read) , 8.1 Watt (idle) , 1.3 Watt (standby) , 1.3 Watt (sleep)
RoHS, WEEE
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Sound Emission
29 dBA
Type: Hard drive
Capacity: 2TB
Brand: WD
Price Range Ex VAT: 50 - 100
