Your basket is empty
WD 8TB Red Pro 3.5" SATA 6Gb/s 7200rpm 128MB NAS Hard Drive
Quicklinx: C5QJWS00 Mfr#: WD8001FFWX
Joining the original color of NAS, WD Red Pro continues the formula of success that has led the WD Red product family by adding support beyond consumer and small business markets into medium and large 8-16 bay business storage systems. WD Red Pro hard drives integrate WD's exclusive technology, NASware, to provide unparalleled support for drive compatibility, reliability, and performance.
WD Red Pro NAS Hard Drive WD8001FFWX - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Advanced Format technology, NAS compatible, NASware technology, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
650 g
5 years warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
205 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
10 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.2 Watt (read) , 7.2 Watt (write) , 5.1 Watt (idle) , 1 Watt (standby) , 1 Watt (sleep)
Apple MacOS, Microsoft Windows
RoHS, TUV Nord, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
