WD 8TB Red 5400 RPM SATA 3.5" 256MB Hard Drive
Quicklinx: DL7DWS00 Mfr#: WD80EFAX
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
  • Compatible
    Tested with a wide range of NAS systems for optimum performance and compatibility.
  • Reliable
    Designed to operate in the always-on environment of a NAS or RAID configuration.
  • High capacity
    The high capacity allows the flexibility to build the optimal NAS solution.
WD Red Plus WD80EFAX - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
Native Command Queuing (NCQ), Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, 24x7 continuous operation
101.6 mm x 147 mm x 26.1 mm
715 g
3-year warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
8.8 Watt (read) , 8.8 Watt (write) , 5.3 Watt (idle) , 0.8 Watt (sleep) , 0.8 Watt (standby)
Apple MacOS, Microsoft Windows
RoHS 2011/65/EU
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
29 dBA
