WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
Compatible
Tested with a wide range of NAS systems for optimum performance and compatibility. -
Reliable
Designed to operate in the always-on environment of a NAS or RAID configuration. -
High capacity
The high capacity allows the flexibility to build the optimal NAS solution.
- WD Red Plus WD80EFAX - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 5400 rpm
- Native Command Queuing (NCQ), Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, 24x7 continuous operation
- 101.6 mm x 147 mm x 26.1 mm
- 715 g
- 3-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 715 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps
- Spindle Speed
- 5400 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 8.8 Watt (read) , 8.8 Watt (write) , 5.3 Watt (idle) , 0.8 Watt (sleep) , 0.8 Watt (standby)
- OS Required
- Apple MacOS, Microsoft Windows
- RoHS 2011/65/EU
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Sound Emission
- 29 dBA
