WD 8TB Purple SATA 6Gb/s 3.5" 256MB 5400RPM Surveillance HDD
Built for mainstream surveillance DVRs and NVRs
Quicklinx: DL7FWS00 Mfr#: WD81PURZ
Built for 24/7, always-on, high-definition security systems. With an impressive workload rate and support for many cameras, WD Purple drives are optimized for surveillance systems.
  • The right drive for the job
    WD Purple drives have been engineered specifically for the extreme demands of high temperature, 24/7 surveillance systems.
  • Performance you can trust
    WD Purple is engineered for quality video playback when you need it most.
  • Expand your view
    WD Purple drives are optimized to support many cameras, giving you flexibility to upgrade or expand your security system.
WD Purple Surveillance Hard Drive WD81PURZ - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal - Time-Limited Error Recovery (TLER), Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 continuous operation, AllFrame 4K
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
101.6 mm x 147 mm x 26.1 mm
715 g
Worldwide
3-year warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
213 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
9 Watt (read) , 9 Watt (write) , 8.12 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
RoHS, Directive 2011/65/EU
Worldwide
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
27 dBA
