WD Purple Surveillance Storage offers exclusive AllFrame technology to bring you premium reliability and peace-of-mind when installing your home or small to medium business security system. WD Purple's exclusive firmware upgrades work with ATA streaming to reduce error pixilation and video interruptions that occur when desktop hard drives are incorrectly used as storage in security systems. WD Purple Surveillance Storage is built for 24/7, always-on, high-definition surveillance security systems that use up to eight hard drives and up to 32 cameras.
You wouldn't use a bicycle to transport cargo across the country because it's not the right tool for the job. You also shouldn't use a desktop hard drive in your surveillance security system because it wasn't designed for that application. WD Purple surveillance-class storage has been tested to be compatible in a wide-range of security systems. These drives are designed to replace standard desktop drives that were not designed for the harsh 24/7 always-on, high-definition surveillance environment. Desktop drives are built to run for only short intervals and are not engineered to withstand high-temperature fluctuations and equipment vibrations found in a typical surveillance application.
Surveillance you can trust
With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust. -
WD's exclusive AllFrame 4K technology
All WD Purple drives are equipped with AllFrame 4K technology, which improves ATA streaming to help reduce frame loss, improve overall video playback, and increase the number of hard drive bays supported within a NVR. Futureproof your surveillance solution knowing that WD Purple is ready for ultra high definition cameras. -
Enhanced workload rating
With a high workload rating WD Purple is designed to handle the unique demands of modern video surveillance DVR and NVR systems. -
Wide compatibility, seamless integration
WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you. -
Less power, more efficient
With exclusive IntelliSeek technology, WD Purple drives are able to calculate optimum seek speeds. This keeps power consumption low so ambient noise and vibrations are at a minimum.
- WD Purple WD80PUZX - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5400 rpm
- Time-Limited Error Recovery (TLER), Advanced Format technology, AllFrame, surveillance system compatible, 24x7 availability
- 101.6 mm x 147 mm x 26.1 mm
- 650 g
- 3-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 650 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 178 MBps
- Spindle Speed
- 5400 rpm
Reliability
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 6.4 Watt (read) , 6.4 Watt (write) , 0.7 Watt (idle) , 0.7 Watt (standby) , 5.7 Watt (sleep)
- ICES-003 Class B, Directive 2002/95/EC, NMB-3 Class B
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Sound Emission
- 29 dBA
