Product
WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM Enterprise-Class Drive
Quicklinx: D35LWS00 Mfr#: WD8003FRYZ
Featuring up to ten times the workload capacity of desktop drives, WD Gold hard drives are designed from the ground up for enterprise-class reliability, capacity, power efficiency and performance.
  • High workload rating
    Delivering dependable performance to any storage environment, WD Gold hard drives are designed with a workload rating up to 550TB per year, among the highest of any 3.5-inch hard drive.
  • HelioSeal technology
    Featured in over 15 million Western Digital hard drives shipped, HelioSeal technology allows for higher capacities and less turbulence on large storage arrays. And now on its 4th generation design, HelioSeal technology is field-tested and proven to deliver high capacity, reliability, and power efficiency you can trust.
  • Vibration protection
    Enhanced RAFF technology uses sophisticated electronics to monitor the drive and correct linear and rotational vibrations in real time for improved performance versus WD's desktop drives in high-vibration environments.
  • RAID-specific, time-limited error recovery
    Time-limited error recovery helps to reduce drive fallout within a storage environment caused by the extended hard drive error-recovery processes common to desktop drives.
  • Dynamic fly height technology
    Each read-write head's fly height is adjusted in real time to ensure consistent performance for reduced errors and optimized reliability.
WD Gold Enterprise-Class Hard Drive WD8003FRYZ - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
101.6 mm x 147 mm x 26.1 mm
650 g
5 years warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
205 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.2 Watt (read) , 7 Watt (write) , 7.4 Watt (random read) , 5.1 Watt (idle)
Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years , Technical support - phone consulting - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine wave
Sound Emission
20 dBA
