WD 750GB Elements Portable Hard Drive USB 3.0 2.5" - Black
Quicklinx: B4M4WS00 Mfr#: WDBUZG7500ABK-EESN
USB 3.0 connectivity delivers maximum performance for transferring files to and from this drive.
With 750 GB capacity in a lightweight design, this drive is the ideal companion for users on the go.
When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements portable storage and get your laptop moving again.
  • Maximum transfer rates
  • High-capacity in a sleek design
  • Improve PC performance
WD Elements Portable WDBUZG7500ABK - hard drive - 750 GB - USB 3.0
Hard drive - external (portable)
750 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted, cloud backup
Power Source
USB bus
82 mm x 111 mm x 15 mm
134 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
750 GB
USB 3.0
82 mm
111 mm
15 mm
134 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable
Plug and Play, RoHS
5 °C
35 °C
