WD 750GB Blue SATA 6Gb/s 8MB 2.5" Hard Drive w/ WD Care Express
Quicklinx: 9KQWWS00 Mfr#: WD7500BPVX?CAREEXP
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
WD Blue WD7500BPVX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock Guard, WhisperDrive, SecurePark, Advanced Format technology
69.85 mm x 100.2 mm x 9.5 mm
150 g
750 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
9.5 mm
150 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
138 MBps
Track-to-Track Seek Time
2 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
RoHS
60 °C
8 - 95%
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
