WD 750GB Blue SATA 6Gb/s 16MB 2.5" Hard Drive w/ WD Care Express
Quicklinx: 9KR9WS00 Mfr#: WD7500LPCX?CAREEXP
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
  • The original
  • WD quality
  • More options
  • NoTouch Ramp Load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. SATA or PATA interface. While SATA has become the industry standard interface, WD continues to manufacture desktop drives with a PATA interface for unique or legacy systems.
  • Tested for compatibility
    WD perform tests on hundreds of systems and a multitude of platforms in the FIT Lab to give the customers confidence that the drives will work in their systems.Upgrading your drive is easy.
  • The WD advantage
    WD puts the products through extensive Functional Integrity Testing prior to any product launch. This testing ensures the products consistently meet the highest quality and reliability standards of the WD brand.
WD Blue WD7500LPCX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
750 GB
2.5"
SATA 6Gb/s
Buffer Size
16 MB
S.M.A.R.T.
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
140 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
RoHS
60 °C
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
