WD 6TB Elements Desktop Hard Drive Black
Quicklinx: DL0XWS00 Mfr#: WDBWLG0060HBK-EESN
Form Factor: 3.5
Capacity: 6TB
Interface: USB 3.0
Hurry, only 3 left in stock!
£119.01 ex VAT
£142.81 inc VAT
WD Elements desktop storage with USB 3.0 offers reliable, add-on storage, ultrafast data transfer rates and universal connectivity with USB 3.0 and USB 2.0 devices. The sleek design features generous capacity, renowned WD quality.
  • Transfer files faster than ever
    When connected to a SuperSpeed USB 3.0 port, WD Elements lets you access and save files faster than ever. Transfer a 2-hour HD movie in just 3 minutes instead of 13 minutes.
  • USB 3.0 and USB 2.0 compatibility
    With this single drive you get compatibility with the advanced USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
  • Sleek drive, massive capacity
    The sleek design offers generous capacity, making WD Elements desktop storage the ideal solution for easy, add-on storage for all your important photos, music, videos and files.
  • Improve PC performance
    When your internal hard drive is almost full, your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements desktop storage and get your computer moving again.
  • WD quality inside and out
    WD knows, your data is important to you. So WD builds the drive inside to the demanding requirements for durability, shock tolerance, and long-term reliability. Then WD protects the drive with a durable enclosure, designed for style and protection.
  • Plug-and-Play simplicity
    Formatted to work right out of the box with your PC. Just connect the power and plug the drive into the USB port on your computer to instantly add more storage.
WD Elements Desktop WDBWLG0060HBK - hard drive - 6 TB - USB 3.0
Hard drive - external (desktop)
6 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
Included AC adapter
Enclosure Colour
48 mm x 135 mm x 165.8 mm
EMEA
6 TB
USB 3.0
48 mm
135 mm
165.8 mm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
EMEA
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
Form Factor: 3.5
Capacity: 6TB
Interface: USB 3.0
Brand: WD
