WD 6TB Blue 5400 RPM SATA 3.5" 256MB Hard Drive
Quicklinx: F3X0WS00 Mfr#: WD60EZAZ
Form Factor: 3.5"
Type: Hard drive
Capacity: 6TB
Spin Speed (rpm): 5400rpm
30 in stock
£156.87 ex VAT
£188.24 inc VAT
Western Digital WD Blue PC hard drives deliver solid reliability for office and web applications, and they are perfect for extra storage for desktop PC computing.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
  • NoTouch Ramp Load technology
    Safely positions the recording head off the disk surface to protect your data.
WD Blue WD60EZAZ - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal - NoTouch ramp load technology, Advanced Format technology
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
750 g
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.8 Watt (read/write) , 3.1 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep)
Software Included
Acronis True Image WD Edition
TUV Nord, RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5"
Type: Hard drive
Capacity: 6TB
Brand: WD
Price Range Ex VAT: 150 - 300
