WD 6TB Black 3.5" SATA 6Gb/s 7200RPM 128MB Performance Drive
Quicklinx: CT0SWS00 Mfr#: WD6002FZWX
WD Black performance storage is designed to enhance your PC experience across heavier computing tasks whether you are a digital artist, video editor, photographer, or gamer. The WD Black drive is optimized for drive performance so you can spend more time experiencing the things you love most.
  • Inspiring performance and capacity
  • For creative professionals
    When it comes to storing your creativity and entire digital portfolio, look no further than WD Black performance storage for your solution. Use the WD Black drive for storing your large multimedia files of photos, videos, games or applications and programs because with a WD Black drive, you get an amazing combination of speed, capacity and larger cache sizes.
  • For gamers
    The WD Black drive is the perfect storage solution for your gaming machine by offering large capacities to store your game's downloadable content (DLC), larger cache sizes, and is the perfect compliment for maximum system performance when combined with an SSD.
  • Increased reliability
    The WD Black drive is equipped with StableTrac technology by securing the motor shaft inside to increase reliability and help reduce impact due to system-induced vibrations from other components. By stabilizing the platters inside, the WD Black drive results in more accurate tracking in a particular sector during read and write operations, optimizing performance and reliability.
  • Increased DRAM cache
    The WD Black drive delivers high-speed transfer speeds and read rates of your files with impressive cache sizes. WD's Dynamic Cache technology improves caching algorithms in real time to allocate and optimize cache between reads and writes. This movement of cache for read data helps to reduce congestion and increase overall performance.
  • Efficient processing
    When it comes to processing power, more is always better especially for loading games or large multimedia files. The WD Black drive features a powerful processor that offers high processing capability to maximize drive performance for faster read and write speeds.
WD Black Performance Hard Drive WD6002FZWX - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
StableTrac, dual processor, Advanced Format technology, DRAM cache
101.6 mm x 147 mm x 26.1 mm
720 g
5-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
227 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.1 Watt (idle) , 9.1 Watt (read) , 9.1 Watt (write) , 1 Watt (sleep)
Directive 2002/95/EC
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Sound Emission
29 dBA
