Product
Brand
WD 6TB (2 x 3TB) USB 3.0 My Book Duo Premium RAID Storage
Quicklinx: 9M14WS00 Mfr#: WDBLWE0060JCH-EESN
Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, local, cloud and system-level backup options, hardware RAID and password protection, My Book Duo is the ultimate storage solution offering the capacity and security you need.
WD My Book Duo WDBLWE0060JCH - hard drive array
Hard drive array
Total Array Capacity
6 TB
USB 3.0
2 (installed) / 2 (max)
Middle East, Africa, Europe
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 3 TB
Apple MacOS X, Microsoft Windows Vista / 7 / 8
AC 120/230 V - 50/60 Hz
Microsoft Certification
Compatible with Windows 7
9.9 cm x 15.7 cm x 16.5 cm
2.18 kg
2 years warranty
Hard drive array
Enclosure Colour
Charcoal grey
Chassis
2
Supported Devices / Modules Qty
2
Storage
6 TB
HDD Array External Interface
USB 3.0
Storage Controller
RAID
Data Transfer Rate
290 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
2 x 3 TB
Expansion Bays
2 (total) / 0 (free) x internal
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B
Hardware encryption, password security
1 x USB 3.0 cable
Software Included
WD Security, WD Drive Utilities, WD SmartWare Pro, Acronis True Image WD Edition
RoHS, AES-256
External power adapter
9.9 cm
15.7 cm
16.5 cm
2.18 kg
35 °C
