HGST extends its technology with the introduction of the Ultrastar SN200 series hard drives. The Ultrastar SN200 series hard drives deliver another level of performance and capacity for enterprise, cloud and hyperscale environments. Enabling faster intelligence in the expanding digital demands of business applications the Ultrastar SN200 series hard drives are a reliable resource for fast access to critical data. The HGST Ultrastar SN200 series hard drives increas the speed within the same power envelope.
Ultra-low latency and high quality of service (QoS)
To meet Tier 1 enterprise service level agreements (SLAs), data center managers need high QoS from their storage infrastructure. Ultrastar DC SN200 delivers a 30% improvement over its predecessor providing consistent low latency as the device reaches its highest levels of throughput. The combination of high throughput performance and predictable low latency delivers extreme performance for today's data intensive applications. -
Enterprise storage experience in dual port
Ultrastar SSDs leverage decades of enterprise storage design expertise in high performance and high reliability to deliver this dual-port NVMe SSD 2.5-inch drive. The dual-port feature supports two redundant paths to an SSD, ensuring access to data in the event of a failure in the data path.
- WD Ultrastar SN200 HUSMR7664BHP301 - solid state drive - 6.4 TB - PCIe 3.0 x8 (NVMe)
- Solid state drive - internal
- Capacity
- 6.4 TB
- Form Factor
- PCIe card (HHHL)
- Interface
- Secure Erase function, PowerSave technology, End-to-end data path protection, flash-aware RAID
- 14.49 mm x 167.65 mm x 68.9 mm
- 229 g
- 5-year warranty
- Capacity
- 6.4 TB
- Form Factor
- PCIe card (HHHL)
- Interface
- 14.49 mm
- 167.65 mm
- 68.9 mm
- 229 g
Performance
- Drive Writes Per Day (DWPD)
- 3
- Internal Data Rate
- 6170 MBps (read) / 2200 MBps (write)
- Maximum 4KB Random Write
- 200000 IOPS
- Maximum 4KB Random Read
- 1200000 IOPS
- Average Latency
- 20 µs
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x PCI Express 3.0 x8 (NVMe)
- Compatible Bay
- PCIe card (HHHL)
- Power Consumption
- 25 Watt (typical) , 9 Watt (idle)
- UL, TUV, VCCI, BSMI, KCC, ICES, EMI, RCM, RoHS 2011/65/EU
- Limited warranty - 5 years
- 0 °C
- 55 °C
