WD 500GB WD Blue NVMe M.2 SSD
Quicklinx: F4D0WS00 Mfr#: WDS500G1B0C
Form Factor: M.2 2280
Capacity: 500GB, 500GB
Interface: PCI Express 3.0 x2 (NVMe)
Type: Internal hard drive
£68.42 ex VAT
£82.10 inc VAT
Marketing description is not available.
  • Transfer speeds up to 1700MB/S
    Delivers sequential read speeds up to 1700MB/s and sequential write speeds up to 1450MB/s (500GB model).
  • In-house controller and 3D NAND
    The in-house controller and 3D NAND supports the PCIe NVMe interface and DRAM-less configurations.
  • Low power draw
    Enables a low power draw while maintaining significantly higher performance over SATA SSD.
  • Downloadable WD SSD Dashboard
    Monitor your drive's available capacity, operating temperatures, SMART attributes and more with the WD SSD Dashboard.
WD Blue SN500 NVMe SSD WDS500G1B0C - solid state drive - 500 GB - PCI Express 3.0 x2 (NVMe)
Solid state drive - internal - 3D NAND Technology
500 GB
M.2 2280
3D NAND Technology
22 mm x 80 mm x 2.38 mm
6.5 g
5-year warranty
500 GB
M.2 2280
3D NAND Technology
22 mm
80 mm
2.38 mm
6.5 g
Performance
SSD Endurance
300 TB
Internal Data Rate
1700 MBps (read) / 1450 MBps (write)
4KB Random Read
275000 IOPS
4KB Random Write
300000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x2 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
75 mW (average) , 25 mW (low power active) , 2.5 mW (sleep)
UL, TUV, VCCI, C-Tick, BSMI, FCC, KCC
Limited warranty - 5 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
Capacity: 500GB
Capacity: 500GB
Brand: WD
Price Range Ex VAT: 50 - 100
