WD 500GB My Passport AV TV USB 3.0 2.5" Portable Hard Drive
Quicklinx: 9LCYWS00 Mfr#: WDBHDK5000ABK-EESN
Watch your favorite entertainment on your schedule. Attach this drive to your recordable TV and save all your favorite programs, movies, and sporting events and watch them whenever you want. Created with an AV-grade drive inside, My Passport AV-TV delivers high-quality recording and crystal-clear playback of all your favorite programs making it the perfect drive for your recordable TV.
  • Built to thrive
  • Maximum compatibility
    My Passport AV-TV works with both USB 3.0 and USB 2.0 interfaces and is specifically designed for multimedia storage, making it compatible with most recordable TVs and other consumer electronic devices.
  • USB 3.0 for simultaneous recording and playback
    Super-fast USB 3.0 enables multiple HD streams for simultaneous recording and playback on new dual-tuner TVs. Record your favorite sitcom while watching the big match and never miss a moment of the action.
  • Seamless installation
    The small My Passport AV-TV fits neatly in your entertainment center. Use the included bracket mounting kit to easily attach it directly to the back of your TV for out-of-sight recording and playback.
  • Engineered to last
    My Passport AV-TV is designed to withstand the high demands of always-on, video streaming environments, giving you 24x7 reliability.
  • USB powered
    Powered only by the USB port on your recordable TV, My Passport AV-TV gives you all the TV recording storage you need without the clutter of cables.
WD My Passport AV-TV WDBHDK5000ABK - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
82.66 mm x 123.46 mm x 18.6 mm
148.1 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
500 GB
USB 3.0
82.66 mm
123.46 mm
18.6 mm
148.1 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
1 x USB cable - 82 cm
Mounting Kit
Included
RoHS
Enclosure Colour
35 °C
0 - 60%
