Product
Brand
WD 500GB Elements 2.5" USB 3.0 Portable External Hard Drive - Black
Quicklinx: DM81WS00 Mfr#: WDBUZG5000ABK-WESN
More than 50 in stock
£33.87 ex VAT
£40.64 inc VAT
Standard delivery Delivered within 3-5 working days
For years, millions of people worldwide have trusted their data to WD hard drives, and its first concern is to reliably store that data. So this drive was built for durability, shock tolerance and long-term reliability. With this single drive you get compatibility with USB 3.0 devices and backward compatibility with USB 2.0 devices as well. With a huge capacity in a lightweight design, this drive is the ideal companion for users on the go.
WD Elements Portable WDBUZG5000ABK - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
USB bus
110.6 mm x 82.1 mm x 15 mm
130 g
Worldwide
500 GB
USB 3.0
NTFS formatted
110.6 mm
82.1 mm
15 mm
130 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows 7 / 8.1 / 10
1 x USB cable
RoHS
Worldwide
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
Brand: WD
Price Range Ex VAT: 0 - 50
