WD 500GB Blue 3.5" SATA 6Gb/s 7200rpm 32MB Hard Drive
Quicklinx: C2GSWS00 Mfr#: WD5000AZLX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£32.59 ex VAT
£39.10 inc VAT
Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
WD Blue storage is designed and manufactured with technology found in WD's original award-winning desktop and mobile hard drives. WD Blue sets the baseline for everyday storage by consistently delivering improved performance over previous generations while successfully maintaining WD's quality and reliability for over six generations. The difference is that their colors never fade, generation after generation.
WD Blue is available in a broad range of entry-level capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system. However, not all hard drives are created equally and for your applications that demand more, WD gives you the power of choice.
  • Trusted engineering
  • A modern classic
  • Your power of choice
  • Recommended use
    WD Blue storage is tested and recommended for use in desktop and All-in-One PCs, industrial applications, notebooks, and external enclosures where capacity is not needed. For additional capacity, look at WD Green capacity storage drives.
WD Blue WD5000AZLX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal - NoTouch ramp load technology
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
NoTouch ramp load technology, S.M.A.R.T.
101.6 mm x 147 mm x 25.4 mm
440 g
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
32 MB
101.6 mm
147 mm
25.4 mm
440 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.8 Watt (read) , 6.8 Watt (write) , 6.1 Watt (idle) , 1.2 Watt (standby) , 1.2 Watt (sleep)
RoHS, NMB-3 Class B, CAN ICES-3 Class B
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
350 g @ 1 ms
Sound Emission
29 dBA
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: WD
Price Range Ex VAT: 0 - 50
