WD 500GB Black 2.5" 7mm 7200RPM SATA 6Gb/s 64MB Cache HDD
Quicklinx: FM18WS00 Mfr#: WD10SPSX
£62.02 ex VAT
£74.42 inc VAT
Give yourself the room to bring your enormous digital portfolio wherever you're at with WD Black Mobile Hard Drives. With up to 1TB of 7200 RPM high-performance storage, WD Black Mobile Hard Drives give you the power to create while on the go, so you can offload, edit, and shoot without fear of running out of space anytime soon.
  • Specifically designed for small form factor desktops, laptops, and Mac computers
  • Performance 2.5-inch hard drives
  • Designed for creative professionals, gamers, and system builders
WD Black WD10SPSX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Advanced Format technology
69.85 mm x 100.2 mm x 7 mm
92 g
5-year warranty
1 TB
2.5"
SATA 6Gb/s
Buffer Size
64 MB
69.85 mm
100.2 mm
7 mm
92 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
0.85 Watt (idle) , 2 Watt (read) , 2 Watt (write) , 0.25 Watt (sleep) , 0.25 Watt (standby)
RoHS 2011/65/EU
Limited warranty - 5 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
