WD 500GB AV-GP SATA 3Gb/s 16MB 5400RPM 2.5" Hard Drive
Quicklinx: 8RH1WS00 Mfr#: WD5000LUCT
Form Factor: 2.5"
Type: Hard drive
Interface Type: Serial ATA-300
Capacity: 500GB, 500GB
Spin Speed (rpm): 5400rpm
£38.43 ex VAT
£46.11 inc VAT
WD AV-25 2.5-inch SATA hard drives are specially engineered to offer cool quiet operation while providing maximum reliability in 24 x 7 always-on environments. With support for up to five simultaneous HD video streams, these drives are perfect for DVRs, digital video surveillance and other demanding multimedia applications.
  • 24 x 7 reliability
    These drives are designed to last in always-on streaming digital audio/video environments such as DVR/PVR, digital video surveillance and other demanding multimedia applications.
  • Advanced format technology
    Leading edge technology delivers improved video quality and AV performance through enhanced error correction capability.
  • SilkStream technology
    Optimized for smooth, continuous digital video playback of up to five simultaneous HD streams. SilkStream is compatible with the ATA streaming command set so AV customers can use standard streaming management and error recovery options.
  • Ultra-cool operation
    A cool drives is a more reliable drive. WD continues to develop new and innovative ways to keep drives cool while they are operating.
  • Quiet
    Noise levels have been minimized to less than one sone - virtually below the threshold of human hearing.
  • Low power consumption
    The drive draws less than 2 Watts while operating and a mere 4.75 Watts during spin up.
  • 1 million hours MTTF (MTBF)
    Best-in-class reliability for small-form factor AV storage.
  • Preemptive Wear Leveling (PWL)
    The drive arm frequently sweeps across the disk to reduce uneven wear on the drive surface common to audio video streaming applications.
WD AV-25 WD5000LUCT - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
Preemptive Wear Leveling (PWL), SilkStream, Advanced Format technology
69.85 mm x 100.2 mm x 6.8 mm
92 g
3-year warranty
500 GB
2.5"
SATA 3Gb/s
Buffer Size
16 MB
69.85 mm
100.2 mm
6.8 mm
92 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
147 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
RoHS
Limited warranty - 3 years
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Form Factor: 2.5"
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: WD
