WD 4TB Ultrastar DC HC310 7200 RPM SATA 3.5" Hard Drive
Quicklinx: DTNVWS00 Mfr#: 0B35950
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
43 in stock
£129.48 ex VAT
£155.37 inc VAT
As the industry evolves to develop purpose-built solutions for growing data storage requirements, IT managers continue to rely on lower capacity drives that are economical to acquire, yet deliver quick and reliable data access for traditional data center applications. Ultrastar 7K6 is a low-capacity HDD, that helps address economic and access requirements of many traditional IT workloads. Lower capacity drives also help address architecture limitations. The Ultrastar 7K6 is designed for traditional storage and server applications as well as distributed and scalable computing, including block and file storage architectures, providing economical capacities, fast performance and lower cost to help ease budget constraints.
WD Ultrastar DC HC310 HUS726T4TALA6L4 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal - Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), Dynamic fly height technology, advanced format 512n
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
101.6 mm x 147 mm x 26.1 mm
715 g
5-year warranty
4 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
201 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7 Watt (active) , 5.9 Watt (idle)
RoHS 2011/65/EU
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
0.67 g @ 5-500 Hz
Vibration Tolerance (non-operating)
1.04 g @ 2-200 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: WD
Price Range Ex VAT: 100 - 150
