WD 4TB Black 3.5" SATA 6Gb/s 7200RPM 128MB Hard Drive
Quicklinx: DL7BWS00 Mfr#: WD4005FZBX
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Spin Speed (rpm): 7200rpm
12 in stock
£144.92 ex VAT
£173.90 inc VAT
WD Black performance storage is designed to enhance your PC experience across heavier computing tasks whether you are a digital artist, video editor, photographer, or gamer. Available with up to 256MB of DRAM cache on higher capacity models, the WD Black drive is optimized for drive performance so you can spend more time experiencing the things you love most.
WD Black WD4005FZBX - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal - StableTrac, Advanced Format technology, DRAM cache
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.6 mm x 147 mm x 26.1 mm
720 g
5-year warranty
4 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
202 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.1 Watt (idle) , 9.1 Watt (read) , 9.1 Watt (write) , 1 Watt (sleep)
RoHS 2011/65/EU
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Sound Emission
29 dBA
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: WD
Price Range Ex VAT: 100 - 150
