WD 4TB AV-GP SATA 6GB/s 64MB 3.5" Hard Drive
Quicklinx: 99CDWS00 Mfr#: WD40EURX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
£104.72 ex VAT
£125.66 inc VAT
Power-conserving WD AV-GP SATA hard drives take advantage of WD's GreenPower technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, Set-Top Boxes (STBs) as well as surveillance video recording.
WD AV-GP WD40EURX - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal - Data Lifeguard, IntelliPower, GreenPower technology, Advanced Format technology
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Data Lifeguard, IntelliPower, GreenPower technology, Advanced Format technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
680 g
3-year warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
5.1 Watt (read) , 5.1 Watt (write) , 4.5 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
5 - 95% (non-condensing)
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Vibration Tolerance
0.75 g @ 20-300 Hz (operating) / 4 g @ 20-500 Hz (non-operating)
Sound Emission
26 dBA
Type: Hard drive
Capacity: 4TB
Brand: WD
Price Range Ex VAT: 100 - 150
