WD 480GB Green SATA 6Gb/s 2.5" SSD M.2 2280
Quicklinx: F8LHWS00 Mfr#: WDS480G2G0B
Form Factor: M.2 2280
Capacity: 480GB
Interface: Serial ATA-600
Type: Internal hard drive
More than 50 in stock
£54.08 ex VAT
£64.89 inc VAT
For fast performance and reliability, WD Green SSDs boost the everyday computing experience in your desktop or laptop PC.
  • Improved performance for everyday computing
    With the performance boost from a WD Green SATA SSD, you can browse the web, play a game, or simply start your system in a flash.
  • Solid state reliability
    Lightweight and shock resistant, WD Green SSDs use no moving parts and help keep your data safe from loss in the case of accidental bumps and drops.
WD Green SSD WDS480G2G0B - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal - shock resistant
480 GB
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, S.M.A.R.T.
22 mm x 80 mm x 1.5 mm
6.52 g
3-year warranty
480 GB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
1.5 mm
6.52 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
545 MBps
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
80 mW (active) , 2800 mW (read) , 2800 mW (write) , 30 mW (sleep) , 10 mW (DevSleep)
Software Included
WD SSD Dashboard
UL, TUV, VCCI, BSMI, FCC, KC, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 3 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
Capacity: 480GB
Brand: WD
Price Range Ex VAT: 50 - 100
