My Passport™ Wireless Pro
High-capacity, wireless mobile storage designed to accompany professional photographers and videographers in the field to easily offload, edit and stream captured photos and high-definition videos. Created to work seamlessly with mobile devices and equipped with a built-in SD card reader, My Passport Wireless Pro is the all-in-one drive you need to streamline your workflow.
• Wireless 802.11ac for fast data transfers
• SD 3.0 card reader for fast media offloads
• All-day battery (up to 10 hours)
• USB power bank to charge mobile devices
• USB 3.0 for super-fast transfers
• USB 2.0 to transfer media from an external storage device
• Plex media server to organize and stream media
• My Cloud app to access from iOS and Android devices
Best-in-class wireless storage
Built with the latest wireless 802.11ac technology delivering fast data transfers and smooth HD media streaming capabilities. Wirelessly transfer images you capture in the field via FTP Mode with your compatible DSLR camera to the drive, where they can be backed up, viewed and edited using a connected tablet or laptop.
Fast SD card media transfers
Integrated SD 3.0 card reader delivers fast media transfers on the go. Offload or copy high-resolution photos and Full HD videos from your camera’s SD card to this high-capacity drive to back up everything you capture and create workflow efficiencies needed to keep you moving.
All-day battery life
Up to 10 hours of continuous use. Bring it on an all-day photo shoot and stay out in the field longer. Take it on a long trip and continuously stream videos on the road or in flight.
Built-in power bank
No electrical outlet? No problem. Charge your smartphone, tablet and other USB devices on the go with the integrated 6,400 mAh power bank. With this convenient feature, everything you need is in one device making it the perfect travel partner.
Super-fast USB 3.0 transfer speeds
Quickly move or copy media to and from your My Passport Wireless Pro with the super-fast data transfer speeds of the USB 3.0 port. This is especially time saving when you need to transfer a large amount of .RAW images or Full HD videos to or from your computer.
Import media from external USB devices
Use the convenient USB 2.0 port to easily transfer media from an external USB storage device, like a compatible DSLR or CF card reader.
Beautifully organize and stream with Plex™
Plex organizes your entire media collection with one simple interface and visually enhances it by adding descriptions, plot summaries, posters and album covers. Wirelessly stream media stored on your My Passport Wireless Pro to all your devices, including your PC and Mac computers, smartphones, tablets, Smart TV and more.
Access files from anywhere
Wirelessly connect My Passport Wireless Pro to your mobile devices using the My Cloud mobile app so you can view, organize, edit and share your media files from anywhere with your tablet and smartphone.
Adobe® Creative Cloud® connected
Adobe Creative Cloud equips you with the tools you need to turn your brilliant ideas into creative masterpieces. And since My Passport Wireless Pro is Creative Cloud connected through the My Cloud mobile app, you can quickly get your photos and videos from your camera to your drive and into the Creative Cloud ecosystem. With just a few clicks on your tablet, you can open, edit and save files wherever you are.
Make your other USB storage devices wireless
When you connect another external USB storage device to your My Passport Wireless Pro, you’ll be able to wirelessly access content on that external device using your computer, or tablet and smartphone using the My Cloud app. It becomes a network share on your My Passport Wireless Pro, so whether you are working from a computer or keeping it light with a tablet, your media is always accessible.
Works with PC and Mac computers out of the box
Formatted ExFAT eliminates the need to reformat your My Passport Wireless Pro. Just start it, connect and go.
Safeguard your captured moments
Wi-Fi password protection helps keep your photography, videography, music and important files safe from unauthorized wireless access. Set up Drive Lock in the device dashboard to prevent USB access to your content in the unlikely event it is lost or stolen.
Create your own Internet hotspot
Use My Passport Wireless Pro as a Wi-Fi hub to share an Internet connection with up to eight (8) devices.
Stream up to 8 HD videos simultaneously
Connect multiple devices to your My Passport Wireless Pro and simultaneously stream up to 8 HD videos (8 videos x 3 Mbps HD MP4 streams). Perfect for sharing video footage from your latest shoot or keeping a group entertained on a long road trip.
Dual wireless band support
My Passport Wireless Pro is conveniently equipped with two different wireless bands: 5GHz 802.11ac band for faster performance on compatible wireless AC devices and 2.4GHz 802.11n band for better long-range performance for both wireless AC and N devices.
Strong Wi-Fi performance
Built with 802.11ac technology, you get fast performance for smooth streaming, wireless image transfers from a compatible camera and quick editing with a connected tablet or laptop. -
Save time with SD 3.0
Equipped with an integrated SD 3.0 card reader to offload or copy photos and videos from your camera's SD card and create a workflow, that keeps you moving. -
With a battery, that provides long hours of continuous use, you stay in the field longer. Bring it on an all-day photo shoot to keep your photos backed up and mobile devices powered.
- WD My Passport Wireless Pro WDBSMT0030BBK - network drive - 3 TB
- Network drive
- Host Connectivity
- USB 3.0 / 802.11ac
- Total Storage Capacity
- 3 TB
- 12.6 cm x 12.6 cm x 2.4 cm
- 450 g ()
- Localisation
- EMEA
- Processor
- Realtek Semiconductor RTD1195PN
- Hard Drive
- 1 x 3 TB
- Card Reader
- Networking
- USB 3.0, 802.11ac
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Android, Apple iOS, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11
- 2-year warranty
- Network drive
- Host Connectivity
- 3 TB
- 12.6 cm
- 12.6 cm
- 2.4 cm
- 450 g ()
- Enclosure Colour
- Black
- Built-in Devices
- Battery
- Localisation
- EMEA
Processor / Memory
- Processors Installed
- RAM
- 512 MB
Hard Drive
- HDD
- Capacity
- 1 x 3 TB
- Buffer Size
- 256 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
- Data Link Protocol
- USB 3.0, 802.11ac
- 2T2R MIMO technology, DLNA Media Server, internet sharing
- Wi-Fi CERTIFIED, DLNA CERTIFIED, UPnP, IEEE 802.11ac
- 1 x USB 3.0 , 1 x USB 2.0
- DriveLock, password security
- Directive 2002/95/EC
- Power Device
- External power adapter
- Voltage Required
- Run Time (Up To)
- 10 hours
- Software Included
- WD My Cloud, WD Backup, WD Access
- OS Required
- Limited warranty - 2 years
- 0 °C
- 35 °C
