Your basket is empty
WD 3TB My Passport Ultra 2.5" USB 3.0 External Portable Hard Drive - Blue
Quicklinx: BGVDWS00 Mfr#: WDBBKD0030BBL-EESN
My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
WD My Passport Ultra WDBBKD0030BBL - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, automatic backup, NTFS formatted, cloud backup
Power Source
USB bus
Enclosure Colour
Noble blue
81.57 mm x 110.07 mm x 20.96 mm
230 g
Middle East, Africa, Europe
3 years warranty
3 TB
Hardware Encryption
256-bit AES
USB 3.0
81.57 mm
110.07 mm
20.96 mm
230 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities
Apple MacOS X, Microsoft Windows Vista / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
Noble blue
Package Type
Retail
Limited warranty - 3 years
5 °C
35 °C
