WD 2TB Red SA500 M.2 2280 SATA 6Gb/s SSD
Quicklinx: FHNRWS00 Mfr#: WDS200T1R0B
Form Factor: M.2 2280
Capacity: 2TB, 2TB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 2 left in stock!
£121.82 ex VAT
£146.18 inc VAT
A SATA III Internal SSD is Ideal for Any NAS Array
The WD Red™ SA500 NAS SATA SSD is an ideal choice for NAS arrays that operate in an always-on, 24/7 environment. Specifically designed and tested for the harsh conditions of a NAS array, WD Red SSDs feature advanced caching to handle even the most demanding applications.
Fast, Reliable SATA III Storage
A WD Red™ SA500 NAS SATA SSD can enhance your NAS’s response time. Efficient caching of big files makes the WD Red SSD ideal for OLTP databases, multi-user environments, photo rendering, 4k and 8k video editing and more.
Blazing-Fast File Access
WD Red SSDs are optimized for fast file access and can cache your most frequently used data for even faster access.
The Endurance of SSD
Because WD Red SSDs have no moving parts, there’s less to wear out over time – heat and vibration are reduced as well.
Work Faster and Save Time
Western Digital® 3D NAND, the WD Red™ SSD delivers outstanding SATA III performance to accelerate your productivity and save you time.
Intense Apps are No Problem
HD Video, 4K and 8K formats require a fast drive that reduces latency for hassle-free editing and transfer of huge multimedia files.
WD Red SA500 WDS200T1R0B - SSD - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
24x7 continuous operation, 3D NAND Technology
22 mm x 80 mm x 2.38 mm
7 g
5-year warranty
2 TB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
2.38 mm
7 g
Performance
SSD Endurance
1300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
85000 IOPS
Reliability
MTBF
2,000,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
60 mW (active) , 3000 mW (read) , 3800 mW (write) , 56 mW (sleep) , 12 mW (DevSleep)
UL, TUV, VCCI, BSMI, FCC, KC, Morocco
Limited warranty - 5 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
Capacity: 2TB
Capacity: 2TB
Brand: WD
