My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
Sleek design with high capacity
This drive is sleek and fast with plenty of capacity for your important digital content. -
Local and cloud backup
WD SmartWare Pro automatic backup software lets you choose when and where you back up your files. -
Ultra-fast transfer rates
When connected to a USB 3.0 port, My Passport Ultra lets you access and save files with blazing speed. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates. -
USB 3.0 and USB 2.0 compatibility
With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well. -
Secure your files
WD Security allows you to set password protection and hardware encryption for your drive to help protect your files from unauthorized use or access. -
USB-powered
Powered directly from the USB port on your PC. No separate power supply is needed.
- WD My Passport Ultra WDBBKD0020BBY - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, automatic backup, NTFS formatted, cloud backup
- Power Source
- USB bus
- Enclosure Colour
- Wild berry
- 81.57 mm x 110.07 mm x 20.96 mm
- 230 g
- Localisation
- Middle East, Africa, Europe
- 3-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Interface
- USB 3.0
- 81.57 mm
- 110.07 mm
- 20.96 mm
- 230 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities
- OS Required
- Apple MacOS X, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB cable - external
- RoHS
- Enclosure Colour
- Wild berry
- Localisation
- Package Type
- Retail
- Limited warranty - 3 years
- 5 °C
- 35 °C
