Product
WD 2TB My Passport X Gaming Storage USB 3.0 Xbox/Win/Mac Portable Hard Drive
Quicklinx: BRJ7WS00 Mfr#: WDBCRM0020BBK-EESN
Form Factor: 2.5"
Capacity: 2TB
Interface: USB 3.0
£73.51 ex VAT
£88.21 inc VAT
My Passport X from WD expands your Xbox One or PC gaming experience. Connect this portable and powerful drive to immediately add storage capacity to your system. Built around a high-quality WD drive, My Passport X is performance-tweaked to meet the desires of serious gamers.
Take your gaming titles wherever you want. You can even plug it into your friend's Xbox One video game system and it's game on! Internet required. Must be logged into your Xbox Live online account.
Connecting My Passport X to your Xbox One is like equipping your gaming avatar with super-lifting strength and speed. It gives you the room to store a lot more games, plus the speed of a USB 3.0 compatibility for a lightning-quick gaming experience. It's built to deliver a great gaming performance for Xbox One or PC gamers.
  • Expand your Xbox One gaming experience
  • Play anywhere
  • Performance tweaked
  • No sweat setup
    My Passport X takes just minutes to set up. Plug it in, follow the easy on-screen instructions - and you're locked and loaded to take on armed marauders, aliens and opponents of all types.
  • Sleek design with high capacity
    An ideal companion for your Xbox One, the My Passport X's stylish, compact design allows you to take your gaming lifestyle with you - and look good doing it.
  • WD reliability
    Your data is important, so WD builds drives for durability, shock tolerance and long-term reliability.
WD My Passport X WDBCRM0020BBK - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant
Power Source
USB bus
Enclosure Colour
8.16 cm x 11 cm x 2.096 cm
230 g
Middle East, Africa, Europe
2 years warranty
2 TB
USB 3.0
Shock resistant
8.16 cm
11 cm
2.096 cm
230 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows Vista, Microsoft Windows 7 / Windows 8 or later
1 x USB cable
Directive 2002/95/EC
Enclosure Colour
5 °C
35 °C
Form Factor: 2.5"
Capacity: 2TB
Interface: USB 3.0
Brand: WD
Price Range Ex VAT: 50 - 100
