This is the one wireless drive for all your devices. Free up space on your tablet and smartphone. Back up or transfer your photos and videos from your SD card to keep on shooting. It's wireless. Portable. It's one drive with no boundaries.
Free of wires and the Internet, My Passport Wireless lets you connect with up to 8 devices at the same time.
Transfer or back up photos and videos from your SD card in the field so that you can keep on shooting. Plus, you can instantly share your creations using any device connected to the drive.
Stay mobile with the long-lasting, built-in, rechargeable battery.
Stream videos, photos and music to connected TV's, media players, gaming consoles and other DLNA/UPnP devices.
Use My Passport Wireless as a Wi-Fi hub to share an Internet connection with multiple devices.
Feel secure from unauthorized access with Wi-Fi password protection for every photo, video, music and important file you save. Plus, protect your drive from USB access using Drive Lock in the device dashboard.
Configure, manage and diagnose your drive using the intuitive dashboard. Run drive diagnostics, format your drive, register your drive and more.
Quickly transfer large amounts of data to the drive using the ultra-fast USB 3.0 port.
Life goes faster with no strings attached
This is the one wireless drive for all your devices. Free up space on your tablet and smartphone. Back up or transfer your photos and videos from your SD card to keep on shooting. It's wireless. Portable. It's one drive with no boundaries. -
You're more attached with no attachments
Free of wires and the Internet, My Passport Wireless lets you connect with up to 8 devices at the same time. -
Built-in SD card slot
Transfer or back up photos and videos from your SD card in the field so that you can keep on shooting. Plus, you can instantly share your creations using any device connected to the drive. -
Rechargeable battery to keep you going
Stay mobile with the long-lasting, built-in, rechargeable battery. -
Stream media to connect devices
Stream videos, photos and music to connected TV's, media players, gaming consoles and other DLNA/UPnP devices. -
Internet sharing
Use My Passport Wireless as a Wi-Fi hub to share an Internet connection with multiple devices. -
Keep your private stuff private
Feel secure from unauthorized access with Wi-Fi password protection for every photo, video, music and important file you save. Plus, protect your drive from USB access using Drive Lock in the device dashboard. -
You're in control
Configure, manage and diagnose your drive using the intuitive dashboard. Run drive diagnostics, format your drive, register your drive and more. -
Ultra-fast USB 3.0
- WD My Passport Wireless WDBDAF0020BBK - network drive - 2 TB
- Network drive
- Host Connectivity
- USB 3.0 / 802.11n
- Total Storage Capacity
- 2 TB
- 8.6 cm x 12.7 cm x 2.98 cm
- 350 g ()
- Localisation
- Middle East, Africa, Europe
- Processor
- Texas Instruments AM3352
- Hard Drive
- 1 x 2 TB
- Card Reader
- Networking
- 802.11b/g/n, USB 3.0
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X, Android, Microsoft Windows Vista / XP / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Network drive
- Host Connectivity
- USB 3.0 / 802.11n
- 2 TB
- 8.6 cm
- 12.7 cm
- 2.98 cm
- 350 g ()
- Enclosure Colour
- Black
- Built-in Devices
- Battery
- Localisation
Processor / Memory
- Processors Installed
- RAM
- 512 MB
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Buffer Size
- 256 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
- Data Link Protocol
- 2T2R MIMO technology, DLNA Media Server, internet sharing
- Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP
- 1 x USB 3.0
- Cables Included
- 1 x USB 3.0 cable
- DriveLock, password security
- RoHS
- Power Device
- External power adapter
- Voltage Required
- Run Time (Up To)
- 20 hour(s)
- Software Included
- WD My Cloud, WD Quickview
- OS Required
- Limited warranty - 2 years
- 0 °C
- 35 °C
