WD 2TB My Passport SSD USB 3.1 - Portable SSD
Quicklinx: F8FLWS00 Mfr#: WDBKVX0020PSL-WESN
The My Passport SSD is portable storage with blazing-fast transfers. It's small enough to fit in your palm with great capacity to hold tons of content. Password protection with hardware encryption helps keep your content secure. Easy to use, the My Passport SSD is shock-resistant, compact storage in a cool, durable design.
  • Transfer files blazing fast
    The My Passport SSD is the fast My Passport drive to date with high speeds using the USB Type-C port to rapidly transfer data. Its blazing-fast speed also gives great performance to help run virtual machines on your computer.
  • Password protection with hardware encryption
    Store growing content on the My Passport SSD to alleviate limited internal storage space. Set a password to help keep it protected with built-in 256-bit AES hardware encryption with WD Security software.
  • Advanced compatibility technology
    The My Passport SSD is compatible with USB Type-C and USB Type-A ports. Also, USB 3.1 Gen 2-ready, and USB 3.0, USB 2.0 and USB-A compatible.
WD My Passport SSD WDBKVX0020PSL - SSD - 2 TB - USB 3.1 Gen 2
Solid state drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant, password authentication, automatic backup, Apple Time Machine compatible
Power Source
USB bus
Enclosure Colour
Black top with gunmetal (medium metallic grey) bottom
45 mm x 90 mm x 10 mm
Worldwide (excluding China)
3-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen 2
45 mm
90 mm
10 mm
Performance
Interface Transfer Rate
Max Data Transfer Rate
540 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13
1 x USB-C cable , 1 x USB-C to USB-A adapter
Directive 2002/95/EC
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
